核电厂DCS安全级设备中PCBA无焊压入式连接工艺可靠性评价研究及应用--控制网
企业:北京广利核系统工程有限公司 日期:2020-08-31
领域:DCS 点击数:520
作者:北京广利核系统工程有限公司 梁中起,李建刚,高超,谢伏巨
摘要:压入式接端是一种适用于压入式连接的具有特殊形状截面的接端。根据压入接端设计的不同,压入式连接分为实心压入式连接和柔性压入式连接两种工艺。本文主要通过对核电站使用柔性压入式连接工艺的PCBA产品进行型式试验并分析了实验数据,在此基础上,探讨柔性压入连接的工艺可靠性,并形成一套柔性压入连接工艺的评价方法。
关键词:无焊压入;工艺可靠性
Abstract: The press-in termination is suitable for solderless pressin connection, which has a special-shaped section. According to the different design of the press-in termination, the press-in connection can be categorized as solid press-in connection and flexible press-in connection. In this paper, through the type test on PCBA products using flexible press-in connection technology in nuclear power plants, and analyzing the experimental data, the process reliability of the compliant press-in connection is discussed and a set of evaluation methods for the compliant press-in connection technology is formed.
Key words: Solderless press-in; Process reliability
在线预览:核电厂DCS安全级设备中PCBA无焊压入式连接工艺可靠性评价研究及应用
摘自《自动化博览》2020年8月刊
