详细介绍: CPU Intel? Pentium 4/Celeron-D LGA775 Processor with 800/1066 MHz FSB speed,1M/2M L2 Cache Intel? Core? 2 Duo Processor, Speed up to 2.66GHz (4MB Cache) RAM 类型和最大性能 2 x DDRII 533/667/800 DIMM, Max 4GB 芯片组 Intel? Q965+ICH8 网络芯片 PCI-E GbE: Intel? 82573L PCI-32 GbE: Intel? 82541PI 10/100/1000 LAN 8 ports copper 10/100 LAN None HDD Supports SATA II, 1 x 3.5 HDD Bay or 2 x 2.5 HDD (Option) CF 1 (Through SATA to IDE Bridge) LAN Bypass GbE LAN Bypass (Three Pairs Dual Latch) 串口 One at front (RJ-45 Connector) IDE/SATA 1/2 USB 2 x in Front Panel PCI 扩展 1 x PCI-X slot LCD 模块 2 x 16, PIO 指示 Power, HDD, Bypass LEDs 电源 350 W ATX Power Supply 外型 1 U 尺寸 427 x 458 x 44 mm 认证 CE FCC Class A 纸箱尺寸 565 x 550 x 160mm 净重 13 Kg | |||
定购网址: |
产品介绍网址: http://www.nexcom.cn/
