  • 深圳市昭营科技有限公司
  • 地址:深圳市南山区科技园中区科发路2号9栋3层
  • 邮编:518057
  • 电话:0755-2650-0777 2650-1777
  • 传真:0755-2650-5111
  • 网址:http://www.icop.com.cn
  • Email:info@icop.com.cn
  • 联系人:
昭营 3.5寸嵌入式电脑模块VSX-6127
厂商:深圳市昭营科技有限公司
  发布时间:08-08-12 09:10
128MB/8S/3USB/VGA/LCD/LAN/GPIO/CF
Specifications:
SoC
DM&P SoC CPU Vortex86SX- 300MHz
Real Time Clock with Lithium Battery Backup
Cache
L1:16K I-Cache, 16K D-Cache
Bus PC/104+ standard compliant
BIOS AMI BIOS
System Memory
128MB DDR2 onboard
Watchdog Timer
0 & 1 Sets Software programmable from 30.5 µsec. To 512 sec. x 2
sets (Watchdog 1 fully compatible with M6117D)
VGA
XGI Volari Z9s Chipset
VGA and TFT/LVDS Flat Panel Interface Support
Onboard 32MB VGA Memory, support resolution up to
1280 x 1024, 16M colors
LAN
Integrated 10/100Mbps Ethernet
Flash Disk
Support Onboard 2MB SPI Flash Disk
MSTI EmbedDisk Module (16MB and above)
Compact Flash Type I/II
I/O Interface
Enhanced IDE port (UltraDMA-100/66/33) x1
FDD x1
RS-232 port x7
RS-232/485 port x1
USB port (Ver2.0) x3
Parallel port x1
16-bit GPIO port x2
10/100Mbps Ethernet port x1
Connectors
2.0mm 44-pin box header for IDE x1
2.0mm 44-pin box header for LCD x1
2.0mm 34-pin box header for FDD x1
2.0mm 26-pin box header for Printer x1
2.0mm 20-pin box header for 16-bit GPIO x2
2.0mm 16-pin header for LVDS x1
2.0mm 10-pin box header for RS-232 x7
2.0mm 10-pin box header for USB x1
2.54mm 4-pin header for +12V, -12V, -5V, GND x1
2.54mm 3-pin header for RS-485 x1
1.25mm 6-pin wafer for JTAG x1
0.8mm 124-pin Mini-PCI card connector x1
External 15-pin D-Sub female connector for VGA x1
External 9-pin D-Sub male connector for RS-232 x1
External RJ-45 connector for Ethernet x1
External USB connector x1
External Mini DIN connector for Keyboard/Mouse x1
Type I/II Compact Flash Slot x1
Power Requirement Single Voltage +5V @ 620mA
Weight 148g
Board Size 102 X 144mm (4.01 x 5.67 inches)
Operating Temperature -20°C ~ +70°C
-40°C ~ +85°C(Optional)
Specifications: Specifications:
