  • 艾讯宏达科技有限公司
  • 地址:北京市海淀区知春路49号希格玛公寓A座1708
  • 邮编:100120
  • 电话:010-88096058
  • 传真:010-88096078
  • 网址:http://www.grantech.com.cn
  • Email:market1@grantech.com
  • 联系人:
艾讯宏达凌动处理器10串口Mini-ITX板SYS76833VGGA-270-10C
厂商:艾讯宏达科技有限公司
  发布时间:09-08-26 14:54
  ·板载英特尔凌动N270处理器(1.6GHz,2.5 W)   ·采用Intel 945GSE+ICH7M芯片组   ·1个240-pin DIMM内存插槽,最大支持2GB DDRII 533内存   ·2个Realtek RTL8111C PCI-E千兆网络控制器   ·支持VGA,LVDS显示,支持双显示   ·10个串口   ·8 个USB2.0接口   ·支持1个PCI,1 个 Mini-PCIe扩展槽
 >> System
Processor                         Intel Atom N270(1.6GHz,2.5W) processor onbaord
Chipset                              Intel 945GSE + ICH7M
DRAM                                 1x DDR2 667/800 DIMM max up to 2GB
BIOS                                    8MB AMI Flash ROM
Power Supply                     ATX-20P with AT/ATX Power Support(SYS76833VGGA-270-10C)
                                              ATX-20P with ATX Power Support(SYS76833VGGA-270-6C)
Watchdog                            Watchdog timer function
Dimension                           170mm x 170mm
>> I/O Ports
HDD                                        2 x SATA-300 interface;1 x IDE(UltraDMA 100/66/33)
Serial Port                              10 x RS232 COM ports(SYS76833VGGA-270-10C)
                                                 6 x RS232 COM ports(SYS76833VGGA-270-6C)
Parallel                                    1 x Parallel port(DB-25 & Box Header)
Audio                                        Realtek ALC622-VC HD audio codec, Box header for front audio
Keyboard/Mouse                    2 x PS/2 for Keyboard and Mouse
LAN                                           2 x Realtek RTL8111C PCI-E Gigabit
USB                                          8 x USB2.0 (4 by onboard header)
Digital I/O                                 4 input; 4 output
Expansion                                1 x PCI, 1 x Mini-PCIe slot expansion
>> Display
Graphics                                   Intel GMA950 up to 224MB video memory
VGA                                            2048x1536 maximum resolution
LVDS                                         18/24 bit dual channel LVDS from Chrontel CH7308(SYS763833VGGA-270-10C)
                                                   18 bit LVDS from 945GSE(SYS76833VGGA-270-6C)
>> Environment
Operation Temperature            0°~60°C (32°~140°F)
Humidity                                      10~90%
产品详情请登录:www.grantech.com.cn
