型号Model
MOTOMAN-EH130 | |
可控轴Controlled Axes
6 (Verticaly articulated) | |
最大动作范围 Maximum Range of |
S-Axis | ±180° |
L-Axis | +76° to ?60° | |
U-Axis | +230° to ?142.5° | |
R-Axis | ±360° | |
B-Axis* | ±130° | |
T-Axis | ±360° | |
最大速度 Maximum |
S-Axis | 2.27 rad/s, 130°/s |
L-Axis | 2.27 rad/s, 130°/s | |
U-Axis | 2.27 rad/s, 130°/s | |
R-Axis | 3.75 rad/s, 215°/s | |
B-Axis | 3.14 rad/s, 180°/s | |
T-Axis | 5.24 rad/s, 300°/s | |
允许力矩 Allowable Moment |
R-Axis | 735 N·m |
B-Axis | 735 N·m | |
T-Axis | 421 N · m | |
允许惯性力矩(GD2/4)Allowable Moment of Inertia | R-Axis | 45 kg·㎡ |
B-Axis | 45 kg·㎡ | |
T-Axis | 15 kg·㎡ | |
本 体 重 量Approximate Mass | 1100 kg | |
定位精度Repeatability | ±0.2 mm | |
载 荷 重 量Payload | 130 kg |
