LGA775, Core 2 Duo /Pentium Dual-Core/Pentium EE/Pentium D/ Pentium 4/ Celeron D
Intel 945GC + ICH7 + FWH
Dual Channel DDRII 667/800 up to 4GB
2 x Intel 82574L PCI-E Gigabit Ethernet
2 x SATAII, 1 x IDE
2 x Serial Ports, 6 x USB2.0
>> System
Processor: LGA775, Core 2 Duo/Pentium Dual-Core/Pentium EE/Pentium D/Pentium 4/ Celeron D
Chipset: Intel 945GC + ICH7 + FWH with 667/800/1066MHz
DRAM: 2 x 240PIN Dual Channel DDRII 667/800 max up to 4GB
BIOS: 4MB AMI BIOS
BUS :PICMG 1.0
Power Supply: Support ACPI V2.0 specification
Watchdog: 1~255 sec Watchdog timer selectable w/Reaset/NMI
Dimension: 338mm x 122mm
>>Rear Panel I/O Ports
VGA: 1 x DB-15 VGA port
LAN: 2 x RJ-45 LAN ports
USB: 2 x USB 2.0/1.1 ports
>> I/O Connectors
SATA :2 x SerialII ATA connector
IDE: 1 x 40-pin IDE connector
LPT:1 x Parallel connector
USB: 2 x connectors for 4 additional external USB 2.0/1.1 ports
Keyboard & Mouse: 1 x mini-DIN-6 PS/2 keyboard & Mouse port
COM :2 x COM ports, COM1 for RS232, COM2 for RS232/422/485
Audio: 1 x front audio connector for line-out and Mic-in jacks
CD-in: 1 x CD-in internal audio connector
Power: 1 x 4-pin ATX +12V power connector
Fan: 2 x Fan connector
>> Display
Graphics: Intel Graphic Media Accelerator 950, Max share 224MB memory
>> Environment
Operation Temperature: 0°~60°C (32°~140°F)
Humidity: 10~90%
产品详情请登录:
http://www.grantech.com.cn
