图尔克(天津)传感器有限公司是图尔克集团在天津注册的全资的子公司。研究,开发和销售工控接近开关传感器及自动化产品。
【原文】With the RI360P-QR24, Turck offers a non-contact inductive universal encoder with high resolution, wear-free operation, which is at the same time immune to magnetic fields. The sensor and the positioning element of the encoder are fully encapsulated and therefore designed as two independent and fully sealed units that work together without contact. Any vibration or shock from the shaft is therefore not passed on to the sensor. This makes the RI360P-QR24 a superior sensor compared to both optical and magnetic encoders. Thanks to its high degree of protection to IP69K and over 18-bit resolution, machine downtimes and maintenance times resulting from encoder wear are from now on a thing of the past, even with high-precision and high-speed applications.
凭借RI360P-QR24,图尔克成为了首家能提供高分辨率、无磨损、抗磁场干扰的非接触通用型电感式编码器的厂商。该编码器的传感和定位元件是完全封装的,并设计成两个独立的密封单元,无接触地一起工作。因此任何来自转轴的振动或冲击都不会传递至传感器。这使得RI360P-QR24成为了一种比光学和磁性编码器都要优异的传感装置。由于它拥有IP69K防护等级和18位分辨率,即使在高精度、高速应用中,也不会由于磨损而增加停机和维修时间。
Turck developed a revolutionary parameterization and mounting concept for the encoder. This turns the RI360P-QR24 into a universal encoder for any standard industrial application. Users can parameterize the device either as an incremental, multi-turn or single-turn encoder. This variant allows the user to also set output signals, switch points and measuring ranges individually via IO Link. Moreover, Turck is offering a high-resolution variant with an SSI output, a Modbus and voltage/current version, as well as an encoder compliant with the e1 specification, for use on mobile machines. The mounting concept of the encoder also extends its application range: Adapter rings enable the encoder to be fitted on all standard shafts with diameters up to 20 millimeters.
图尔克研发了一种革命性的编码器参数配置和安装概念,将RI360P-QR24变成一种适用于任何标准工业应用的通用型编码器。用户可以通过参数将装置配置为增量式、绝对值多圈或单圈式编码器。此外,还可以通过IO Link来设置输出信号、开关点以及测量范围。同时,图尔克的高分辨率型号产品支持SSI, Modbus 和电压电流模拟量输出,还满足了e1 认证以满足移动设备应用的需要。安装上也体现了产品设计的通用性:用户可通过适配环将定位元件连接到不同直径的轴上,只需在库存中保留一个编码器本体,即可通过变径环满足最高20mm的各种应用。
Voted by the visitors of the SPS IPC Drives, TURCK's contactless inductive encoder RI360P-QR24 has won the Automation Award 2013 for the most innovative new development in the field of automation technology. The prize is awarded annually by the magazine elektro Automation. A jury of experts from the congress-committee SPS IPC Drives, VDMA, ZVEI and the editorial office of elektro Automation has first nominated a top-10 list. From these ten proposals the visitors could select their favourite. We would like to thank all the participants, who voted for our new encoder series.
凭借在自动化技术领域一流的创新,图尔克非接触式编码器RI360P-QR24荣获德国2013自动化大奖,此次获奖结果由SPS展会的众多参观者投票选出。 每年elektro Automation杂志都会颁发这一大奖。来自SPS IPC Drives展会组委会、德国机械设备制造业联合会(VDMA)和 德国电气和电子制造商协会(ZVEI)的众多专家,以及elektro Automation杂志编辑首先会提名前十位的获奖名单。参观者从名单中再投票选出他们最喜欢的产品。图尔克非接触式编码器获得这一殊荣是广大客户对图尔克产品的充分肯定,感谢您为图尔克全新非接触式编码器投出宝贵的一票,我们也一定会不断创新,以更高效更完善的产品和服务回馈客户。
