详细介绍: Scanning distance/检出距离 1mm Recommened distance/建议距离 0.8mm Standard sensing object/标准检测物 5*5*1(iron) Response frequwncy/反应频率 2KHZ Hysteresis/磁滞 ≤1O% ofsensing distance Operating Voltage/工作电压 DC:12~24VDC±10% Current consumption/消耗电流 DC:≤8mA No—Load Output Current/负载电流 DC:30V 200mA Max Leakage current/漏电流 DC:≤1.1mA no-Load Residual voltage/残余电压 DC:≤1.5VDC Operating temperature/工作温度范围 -20°C~+70°C Housing/外观方式 ABS/CUPRUM Wiring method/也线方式 4φ*2M/3 Cores Degree of portection/防水等级 IP66 | |||
产品介绍网址: |
