Crydom RPC 系列控制型固态继电器
企业:施耐德电气(中国)有限公司 日期:2008-12-29
领域:SCADA-RTU 点击数:1406
点击察看原图
    产品简介:
    Proportional controller - Ratings from 15A to 40A @ 480 VAC - 500k or 1M Ohm potentiometer control
    详细介绍:
Part Number Control Maximum Load Current Line Voltage Range Specification PDF Check Stock
RPC1215 150K, 1W 15 Amps 90-130 VAC Spec Document Check Stock
RPC1225 150K, 1W 25 Amps 90-130 VAC Spec Document Check Stock
RPC1240 150K, 1W 40 Amps 90-130 VAC Spec Document Check Stock
RPC2415 1M, 1/2W 15 Amps 200-240 VAC Spec Document Check Stock
RPC2425 1M, 1/2W 25 Amps 200-240 VAC Spec Document Check Stock
RPC2440 1M, 1/2W 40 Amps 200-240 VAC Spec Document Check Stock
RPC2490 1M, 1/2W 90 Amps 200-240 VAC Spec Document Check Stock
RPC4815 1M, 1/2W 15 Amps 400-480 VAC Spec Document Check Stock
RPC4825 1M, 1/2W 25 Amps 400-480 VAC Spec Document Check Stock
RPC4840 1M, 1/2W 40 Amps 400-480 VAC Spec Document Check Stock
