技术 |
IEEE 802.3 10Base-T IEEE 802.3u 100Base-TX IEEE 802.3x Flow Control and Back-pressure
性能 |
14,880pps(以太网),148,810pps(快速以太网) | |
界面 |
10/100TX: M12 D-coding 4-pin socket Power: M12 A-coding 5-pin socket | |
PW1/PW2: Power on (绿色) 快速以太口: Link (绿色) / Activity (绿色闪烁) | |
电源需求 |
机械规格 |
213.6 mm (H) x 106.0 mm (W) x 56.5 mm (D) | |
工作环境 |
通过认证 |
FCC Class A; CE/EN55022:2003 Class A; CE/EN61000-3-2:2001 Harmonic Test; CE/EN61000-3-3:1995 Flicker test | |
EN61000-4-2:1998,ESD EN61000-4-3:1998, RS EN61000-4-4:1995, EFT EN61000-4-5:1995, Surge EN61000-4-6:1996, CS EN61000-4-8:PFM | |
