技术 |
IEEE802.3 10Base-T IEEE802.3u 100Base-TX IEEE802.3u 100Base-FX IEEE802.3x flow control
界面 |
2个10/100 Base-TX电口, 自适应 MDI/MDI-X, 自动协商速率 1个100Base-FX光口 | |
10/100 Base-TX: RJ-45 100Base-FX: Duplex SC 电源/继电器报警: 4-pin接线槽
RJ-45 接口: 支持CAT-3, CAT-4, CAT-5屏蔽/非屏蔽双绞线.最大传输距离100m. SC 接口支持多模或单模光纤. 多模光纤: 50/125um 或 62.5/125um. 单模光纤: 8/125um, 9/125um 或 10/125 um.
JetCon1302-m, Multi-mode: 2KM max. distance Link Distance: 2KM (Max.) Wave-length: 1310nm Min Tx Power:-20dBm Max Tx Power:-14dBm Min Rx Sensitivity:0dBm Max Rx Sensitivity:-31dBm Link budget:11dBm
JetCon1302-s, Single-mode: 30KM max. distance Link Distance: 30KM (Max.) Wave-length:1310nm Min Tx Power:-15dBm Max Tx Power:-8dBm Min Rx Sensitivity:0dBm Max Rx Sensitivity:-34dBm Link budget:19dBm
DIP 1~3: 启动或关闭电口port1/port2,光口port3的端口断线报警功能 On: 启动端口断线报警 Off: 关闭端口断线报警
系统: Power(绿灯), Fault(红灯) RJ-45端口: 100Mbps Link (绿灯亮)/Activity(绿灯闪烁) 10Mbps Link (黄灯亮)/Activity(黄灯闪烁) 光口: Link/Activity(绿色) | |
电源需求 |
DC 24V(18~32V)支持电源正负极性反接保护 AC 18~27V, 47~63Hz | |
机械规格 |
111.8mm(H) x 30mm (W) x 98.2mm (D) (含导轨夹) 111.8mm(H) x 30mm (W) x 89.4mm (D) (不含导轨夹) | |
工作环境 |
-10 ~ 70℃(JetCon 1302) -40 ~ 70℃(JetCon 1302-w ) | |
通过认证 |
FCC Class A, CE/EN55022 Class A
EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 EN61000-4-6 EN61000-4-8 EN61000-4-11
632,171小时, MIL-HDBK-217F GB标准 | |
