型号/产品编号 |
国际 |
Digi Connect WAN |
NEW! - Digi Connect WAN GSM Global Quadband GPRS Class 12, EDGE Class 10 with Antenna |
DC-WAN-GE10A-W |
NEW! - Digi Connect WAN CDMA |
Not available |
NEW! - Digi Connect WAN CDMA with Antenna |
Not available |
Digi Connect WAN Remote Gateway |
NEW! - Digi Connect WAN RG GSM |
DC-RG-GE10AW |
NEW! - Digi Connect WAN Remote Gateway CDMA with Antenna |
Not available |
Digi Connect WAN VPN |
NEW! - Digi Connect WAN VPN GSM Global Quadband GPRS Class 12, EDGE Class 10 with Antenna |
DC-VPN-GE10A-W |
NEW! - Digi Connect WAN VPN CDMA with Antenna |
DC-VPN-S1XA-W |
Digi Connect WAN IA |
Digi Connect WAN IA GSM Class 10 EDGE Class 12 GPRS Industrial Cellular Router with Antenna (no power supply) |
DC-WAN-F501 |
Digi Connect WAN IA CDMA 1xRTT Sprint Industrial Cellular Router with Antenna (no power supply) |
Not available |
附件 |
宽温电源 |
76000717 |
DB-9F到DB-9F交叉电缆(4英尺) |
76000642 |
48VDC 到12VDC电源转换器 |
76000696 |
天线 |
双频桌面式天线,带电缆 - 桌面式2.8"双频天线,50欧姆,SMA针式连接器,8英尺低损耗电缆,0 dbi 增益,带磁性固定 |
Not available |
NEW! - 双频单极性天线 - 标准2英寸双频单极性天线,50欧姆,SMA针式连接器,最大增益.8 dbi |
Not available |
双频高增益天线 - 高增益14,50欧姆,SMA针式连接器,14'连接电缆, 低频2 dbi 增益/高频 4 dbi 增益,带磁性固定 |
Not Available |
