  • 公司类型:其他
  • 控制网
  • 地址:北京市海淀区上地十街辉煌国际2号楼1504室
  • 邮编:100085
  • 电话:010-57116291 / 59813326
  • 传真:010-59813329
  • 网址:http://www.kongzhi.net
  • 联系人:市场部
标题A New Approach for Automation of Distributed Systems
技术领域工业以太网
行业
内容
Reinhard Langmann
        The concept Lean Web Automation (LWA) describes a new approach for web-based operation of automation devices in distributed systems, which can be used flexible by means of compact and low-cost software without installation expense on the client side. A dynamic process data transfer in the TCP/IP network is implemented by a javabased application model. This model uses a process data proxy to create at web clients an interface to process data of a remote automation device. A first practical realization of the LWA is the software toolkit Web Access Kit for OPC, which uses OPC as the interface to the process.
1  Initial position
        Since approx. 2 - 3 years, under the keyword
